look how quiet the front is now - also on higher speed 80mls/h ..
installed the sway bar - perfect !!!
Re: installed the sway bar - perfect !!!
How much work was it to install the sway bar - how much disassembly did it involve?
Is the ride rougher over bad pavement?
Also, tell us about that windscreen, it does not appear to be the OEM screen nor the CalSci piece...
Thanks
Thanks
rilawrence
- Has thanked: 13 times
- Been thanked: 8 times
Did you install aluminum sway bar end links? Here's the link: https://www.slingmods.com/canam-ryker-b ... ?vehicle=4.
Should the sway bar and sway bar end links be installed together to get the most benefit?
I think if I were going to upgrade the sway bar, I'd upgrade the plastic bits for those things too.rilawrence wrote: ↑Mon Apr 22, 2019 11:02 amDid you install aluminum sway bar end links? Here's the link: https://www.slingmods.com/canam-ryker-b ... ?vehicle=4.
Got the Wife's installed today. WOW what a chore!! Didn't help it was about 90 degrees in the garage. The directions are vague at best, I didn't remove the side skirts and I didn't remove the left lower suspension arm. It is a great improvement at highway speed 80 mph no problem!! Still seams a little twitchy at high speed though??
Gonna check that out next,I need to get a shop manual though.
