Turn signal fender wire clip
Technical Discussion about the Electrical & Lighting related to the Ryker
Post Reply
Message
Shaolin
Has thanked: 0
Been thanked: 0
#1 Post by Shaolin » Thu Jul 25, 2019 7:52 am
Has anyone else experienced a clip that holds the wiring for the turn signal come loose? This is on the right fender. I was riding and sounds like rubbing against the tire , and noticed the wire clip is hanging loose. Any thoughts or shared experience with this?
TripleTree
Has thanked: 0
Been thanked: 4 times
Re: Turn signal fender wire clip
#2 Post by TripleTree » Fri Aug 23, 2019 7:50 am
Yes, Mine was doing same thing. Burnt thru wire, repaired and put clip back on tiny post but might have to drill small hole and safety tie it in the future if it comes off again.
Bare Wire.jpg (42.52 KiB) Viewed 9900 times
IMG_0599 a.jpg (31.95 KiB) Viewed 9900 times
TripleTree
Has thanked: 0
#3 Post by TripleTree » Mon Nov 04, 2019 5:07 pm
Came off again, I removed both factory clips then drilled small hole in tab on inside of both fenders reattached with safety ties. PROBLEM SOLVED!
TripleTree
Has thanked: 0
#4 Post by TripleTree » Mon Nov 04, 2019 5:14 pm
Here's a picture of the clips that will not hold. I suggest replacing them with safety ties before your tire burns threw your wiring harness.
Dford
Has thanked: 0
Been thanked: 0
#5 Post by Dford » Tue Jun 02, 2020 12:10 pm
thanks for the tip. Yesterday I noticed my left front signal was not working. The wire had been worn thru by the tire. Will take to the dealer to have the wiring replaced.
TripleTree
Has thanked: 0
#6 Post by TripleTree » Tue Jun 02, 2020 4:22 pm
U welcome
Post Reply
