Rear shock
Argyleboy2
- Has thanked: 3 times
turbo_tomato
- Been thanked: 3 times
Re: Rear shock
My 600 has an adjustment collar with 5 positions but it was a pain to adjust. I took it to two different dealers and neither could adjust it. I ended up buying a spanner wrench with a socket attachment and a 24 inch breaker bar and it clicked right over.
- Argyleboy2 • mikey • AZRIDER
- Ryley The Ryker
- Been thanked: 2 times
Rear shock
An adjustable toe arm is IMO worth it either way. I dont like the stock one.
Adjusting rear alignment is a little bit of a pain but it just takes some patience.
- Andrew
- Andrew
Re: Rear shock
Thanks so much for the video I have the all in one spanner to do this but it dose not fit in to the gap, and gives you no room to pull up on I was stumped on how to adjust it, but I did not know that you could get one that fitted to a ratchet.
