Tufskinz has etched out a new mod to keep the tank of the Can-Am Ryker in pristine condition. The “Tufskinz Peel & Stick Tank Protector Pad” molds over the center of the Ryker's tank, and possesses an attractive pattern of successive miniature wings that expand outward as it arches over the gas tank. It is available in flat or glossy carbon fiber, as well as over a dozen color options and details the tank with an assertive personality that makes it stand out from the other bikes on the road. The glossy domed carbon & color options are coated in a clear, UV resistant epoxy resin that ensures it wont lose its luster after being exposed to the sun. The tank protector is useful for avoiding the scratches and divots that form over time on the tank's surface, such as when riders dismount their Ryker with a passenger in tow, and their boots accidentally drag across the tank's surface, or when they lean forward and the heavy zippers or belt buckles, that riders typically wear, rub against the tank. Installation is easy to do at home by cleaning the tank with an alcohol prep pad before applying the tufskinz to the tank, while the two are between 70 and 110 degrees Fahrenheit. This is an excellent mod of choice for anyone who wishes to give their Ryker an elaborate, stylized appearance, while also serving to keep their Ryker's tank in an unblemished state.
>>> This product is available at SlingMods.com here: https://www.slingmods.com/canam-ryker-g ... d-tufskinz
