The Can-Am Ryker is a treasure trove of wide open panels, that beg to be adorned in a layer of stylish Tufskinz. The “Tufskinz Peel & Stick Rear Fender Accent Kit” reworks the tail side of the Ryker in an unmistakable bloom of color, texture, and meticulously cut ridges, that are sure to galvanize the most critical of observers into singing its praises. The kit comes in carbon fiber, raw carbon, and a host of colors that will herald the Ryker as something to be truly admired. Application of the kit is easy and can be done at home. All that is needed in order to install the kit is to make sure the surface it is being applied to is cleaned with an alcohol prep pad, and somewhere between 72 and 110 degrees Fahrenheit. The Tufskinz itself is coated in a transparent layer of UV resistant epoxy resin, to preserve it against the sun as the Ryker races over the open roads. The kit has a circular cut out to show off and accentuate the Ryker's rear emblem, and the whole piece fits marvelously across the tail section of the fender as if it were always meant to be there. Riders will add a whole new look to the Can-Am Ryker with the “Tufskinz Peel & Stick Rear Fender Accent Kit”, and ensure that their ride is the most dazzling thing on three wheels.
This product is available at SlingMods.com here: https://www.slingmods.com/can-am-ryker- ... t-tufskinz
