Carry-on bag install
- Rydernow
- Been thanked: 4 times
I wanted a simple travel bag attachment for behind the seat on my 600. I used the existing two pre-drilled holes under the seat to attach two half inch metal emt tubes, bent 90 degrees at one end and capped them with plastic hole plugs. To attach them, I shoved two pieces of 3/8 ths fuel line into one end and then threaded a couple of fine thread 3/8 ths bolts into the assembly thru the existing holes in the seat back. It works trick but this is just a prototype. I intend to make another out of aluminum round stock and threading one end.
- "Thumbs Up" from:
- cattleshow
