Coolant reservoir leaking
Re: Coolant reservoir leaking
I also thought mine was leaking too, was taken to dealer and they pressure tested and all was good . they showed me that there is a little hole near cap which is the overflow hole ,not sure why they designed it without a hose to lead overflow to the ground. MY coolant level is a little over the cold line when cold so when it heats up I get a little drip coming from the hole.
Rykerrider39
- Been thanked: 10 times
Rykerrider39
Is it normal to have a little drib coming out from that hole or should I be worry.
Rykerrider39
