Our new tubular steel Grille Guard for the Can-Am Ryker is powder coated in a "satin" black finish to compliment the Ryker's body panels. The grille guard not only looks stylish but also extends the front end of the Ryker adding some protection to the factory grille, especially for those of you that plan on using your Ryker Rally to its full potential.
The Grille Guard also features an optional 12" LED light bar that bolts directly up to the grille guard and features a plug and play "handlebar" mounted on/off switch. The switch allows you to run the LED light bar in "low" mode which is perfect for a DRL (Daytime Running Light) or "high" mode which will light up the road ahead when ripping through the canyons on those dark summer nights. The light can also be set to the center position of the switch to turn it "off".
Thanks for the quick reply. Guess that means you don't have the cover to try it out with. When I get a chance, I'll see how much play I have in the front of mine.
Correct. We do not unfortunately have the OE cover to test this for you. My apologies.
