Handlebars Crooked
- Decon Blue
- Has thanked: 56 times
- Been thanked: 25 times
- Decon Blue
				Goodhart59
Re: Handlebars Crooked
went to my dealer for same issue all they did was replace the bolt more lock tight and retighten to specs. I don`t believe this is the answer to the problem
So it’s been almost a month since my dealer Energy Powersports installed the washer to fix the crooked handlebar issue and I’m happy to say that it’s been working great! Don’t know if this is going to be BRP’s final fix on this issue but I understand that there will most likely be a recall notice.
They also installed the brake lock which has given me peace of mind that no one is going to be able to just roll my Ryker away!
Great people at Energy Powersports!
- Decon Blue
Where’s this so called washer being installed ??Rogue wrote: ↑Sun Jul 07, 2019 7:20 pmSo it’s been almost a month since my dealer Energy Powersports installed the washer to fix the crooked handlebar issue and I’m happy to say that it’s been working great! Don’t know if this is going to be BRP’s final fix on this issue but I understand that there will most likely be a recall notice.
- Decon Blue
Again, just where is this supposed washer being installed ?????????
I’ve had the dealers way was to adjust the outer tie rod.
It’s not that it’s the center handle bar shaft that is not centered
I saw a YouTube video once before I got my Ryker Rally and now I can’t find the video and the dealer is clueless on the fix It seemed to be a simple one I just need the tool. If anyone can help it would really be appreciated !!!
- Decon Blue
So I guess you DON’T know where this supposed washer was installed huhRogue wrote: ↑Sun Jul 07, 2019 7:20 pmSo it’s been almost a month since my dealer Energy Powersports installed the washer to fix the crooked handlebar issue and I’m happy to say that it’s been working great! Don’t know if this is going to be BRP’s final fix on this issue but I understand that there will most likely be a recall notice.
- Decon Blue
