If you're looking for an easy way to power your 12v accessories with the ignition signal, this Plug and Play OE style wiring harness is for you. This setup allows for complete plug and play integration into the factory 12v power plug just under the left headlight panel of your Can-Am Ryker. The male and female end allow for multiple units to be daisy chained for convenience. We also include a 2 pin lever lock so that you can connect your + and - accessory wires directly into the terminal block.
>>> This product is now available at SlingMods.com here: https://www.slingmods.com/canam-ryker-1 ... er-harness
Video Installation
12V Plug n Play Accessory Power Harness w/Video Installation
- slingmods
- Has thanked: 86 times
- Been thanked: 50 times
- Contact:
- Freezefm
Our Collection:
Rykers: 2019 Ryker 600 | 2019 Ryker 900 Rally
Spyders: 2017 F3-S | 2018 RT Limited | 2019 F3 Limited | 2020 RT
Slingshots: 2015 Base | 2015 SL | 2016.5 SLE | 2018 SLR | 2020 R
